Api session event editor area generate border areas
API Endpoint: api/session/event/editorarea/generate_border_areas/
Description: Generate new Areas with a specified Border Attribute and a particular width, at borders of nearby Areas, identified by a Filter Attribute
0 REQUIRED (String) Filter Attribute
1 REQUIRED (String) Border Attribute
2 REQUIRED (Floating point number) Border Width
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Filter Attribute", "Border Attribute", 83 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Filter Attribute", "Border Attribute", 75 ]'
JavaScript example POST
 body: '[ "Filter Attribute", "Border Attribute", 83 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/", options)
