Api session event editor area generate inundation areas
API Endpoint: api/session/event/editorarea/generate_inundation_areas/
Description: Generate Water Inundation Area(s) with the Inundation Level Attribute set to the provided value
| 0 | REQUIRED | (Floating point number) | Inundation Level (m) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '16'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '62'JavaScript example POST
body: '16'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/", options)
