Api session event editor area add with attribute
API Endpoint: api/session/event/editorarea/add_with_attribute/
Description: Add an Area with the provided Attribute and value
0 REQUIRED (String) Attribute
1 REQUIRED (Floating point number) Attribute value
200 Integer (Area ID)
curl 'https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Attribute", 53 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Attribute", 21 ]'
JavaScript example POST
 body: '[ "Attribute", 53 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/", options)
