Api session event editor area remove relations
API Endpoint: api/session/event/editorarea/remove_relations/
Description: Remove Relations from an Area
| 0 | REQUIRED | (AREA Integer ID) | Area | |
| 1 | REQUIRED | (Relation or multiple values in array [a, b, c]) | Relations |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorarea/remove_relations/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "OWNER" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorarea/remove_relations/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "OWNER", "CONSTRUCTOR", "DEMOLISHER" ] ]'JavaScript example POST
body: '[ 1, "OWNER" ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/remove_relations/", options)
