Api session event editor area set color
API Endpoint: api/session/event/editorarea/set_color/
Description: Set new color of existing Area
0 REQUIRED (AREA Integer ID or multiple integer values in array [1, 2, 3]) Areas
1 REQUIRED (TColor or multiple values in array [a, b, c]) Area Colors (in ARGB single value Format)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/set_color/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, -65536 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorarea/set_color/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ -65536, -16744448, -16776961 ] ]'
JavaScript example POST
 body: '[ 1, -65536 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/set_color/", options)
