Api session event editor area add relation
API Endpoint: api/session/event/editorarea/add_relation/
Description: Add Relation
0 REQUIRED (AREA Integer ID) Areas
1 REQUIRED (Enumeration) Relation BORDER_A, BORDER_B, BUILDING, CONSTRUCTOR, CONTENT, DEMOLISHER, NETOWNER, OWNER, PARENT, PERMITTER, RECEIVER, RESULT_PARENT, SENDER or WEATHER
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/add_relation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "OWNER" ]'
JavaScript example POST
 body: '[ 1, "OWNER" ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/add_relation/", options)
