Api session event editor area add
API Endpoint: api/session/event/editorarea/add/
Description: Add one or more Areas
0 OPTIONAL (Integer number) Amount (optional)
200 Integer[] (Area IDs)
curl 'https://engine.tygron.com/api/session/event/editorarea/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST
 body: ''
fetch("https://engine.tygron.com/api/session/event/editorarea/add/", options)
