Select attribute (TQL)
| Select | Unit | Description | Fixed clause amount | Polygon based |
| ATTRIBUTE | decimal | Returns the attribute value of an Item found in the first valid clause parameter | No | false |
Allowed clause parameters
| Param | Value | Description | Limits search polygon |
| ADDRESS |
Integer (Item ID), ID, X, Y, XC, YC, XA, YA, XK or YK |
Address with ID. | false |
| AREA |
Area with ID. | true |
| BUILDING |
Building with ID. | false |
| FUNCTION |
Integer (Item ID), ID, X, Y, XA, YA, XK or YK |
Function with ID. | false |
| GRID |
Grid of Grid Overlay with ID. | false |
| GRID_WITH_ATTRIBUTE | Attribute | Grid of Grid Overlay with non zero Attribute value. | false |
| GRIDTYPE |
Grid Type, X, Y, XA, YA |
Grid of Grid Overlay with specified type. | true |
| INDEX |
positive integer, X, Y, XA, YA |
Allows to specify which value in an Attribute' s value array to select. | false |
| INDICATOR |
Indicator with ID. | false |
| ITERATION | positive integer | Query only executes when the current Iteration matches this value. | false |
| KEY | String | Select Attribute based on Overlay Key value. | false |
| MAP |
Map Type, X, Y, XA, YA |
Only Items present in this Map Type. | true |
| MEASURE |
Measure with ID. | false |
| NAME | String | Select Attribute or Global with specified name. | false |
| NEIGHBORHOOD |
Neighborhood with ID. | true |
| NET_CLUSTER |
Net Cluster with ID. | true |
| NET_FUNCTION |
Net Function with ID. | false |
| NET_LINE |
Net Line with ID. | false |
| NET_LOAD |
Net Load with ID. | false |
| NET_TYPE |
Net type, X, Y, XA, YA |
Only Net Items of this Net Type. | false |
| OVERLAY |
| PANEL |
Panel with ID. | false |
| RELATION | Relation | Changes the context of a selected Item to another related Item. | false |
| RESULTTYPE |
Result type, X, Y, XA, YA |
Grid of Grid Overlay with specified Result type. | true |
| SCENARIO |
Scenario with ID. | false |
| TERRAIN |
Terrain of Terrain Type with ID. | true |
| TIMEFRAME |
timeframe, X, Y, XA, YA |
Specifies which Timeframe to select when processing a particular Grid. | false |
| ZONE |
Zone with ID. | true |
- The name of the attribute should be specified by either:
- The Name (TQL Param)
- The Key (TQL Param) in combination with any of the Overlay parameters for specifying the holder of the Key: Grid (TQL Param), Grid with attribute (TQL Param), Gridtype (TQL Param) or Overlay (TQL Param)
