Api session event editor building
Revision as of 08:39, 3 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorbuilding/
API endpoints for Building editing.
Name Description
add Add new Building
add_polygons Add Polygons for Building Section. In case the Building is empty, optionally set ownership to largest Plot Owner of provided MultiPolygon
append_attribute Appended to existing Building Attribute value
duplicate Duplicate existing Building
import Import Building Collection
remove Remove existing Building
remove_attribute Remove Attribute from Building
remove_polygons Delete Polygons for Building Section
set_attribute Set Building Attribute value
set_attributes Set multiple Building Attribute values
set_name Set new name of existing Building
Additional API endpoints:
Name Description
add_geometry Add a custom Building geometry
add_road Add Road
add_section Add Section
add_standard Add Standard
add_underground Add Underground
duplicate_section Duplicate a Building Section.
generate_rotation_angles Calculation a rotation angle for Buildings having the identifying Attribute Polygons, optionally only for specified Buildings.
generate_water_connection Generate Water Connection.
multi_select Multi Select
query Executes a single TQL Query. Note: you can also use the Session/query endpoint to execute multiple statements and get additional inFormation on API usage.
remove_geometries Remove all custom Building geometries
remove_sections Remove Sections
reset_category_values Reset Category Values
reset_function_values Reset Function Values
reset_slanting_roof_height Reset Height of the Slanting Roof of a Building Section
set_category_value Set Category Value
set_decals Set Decals
set_floors Change amount of floors
set_function Set Function
set_function_value Set Function Value
set_owner Set Owner
set_slanting_roof_height Change Height of the Slanting Roof of a Building Section
