Geo Option
Revision as of 08:07, 24 April 2026 by Frank@tygron.nl (talk | contribs)
Geo Option in relation to Sources and Geo Plugins
Geo Options are items that store particular settings used by the Tygron Engine when generating a new project.
New Project Wizard
While selecting new Project's area, advanced options can be accessed.
When choosing the location of the project area during the New Project Wizard, in the second panel of the wizard, the default mode for data selection is Selection. When this option is checked, the Tygron Engine will acquire datasets from a variety of open datasets that are linked to the selected area. Find an overview on which data is used to create a new 3D model on the Project Sources page. The Advanced Options panel can be found above the selection option. When you open this panel the list of a few of the open datasets is displayed. You can choose to include or excluded specific data sources in your project creation.
Editor
Editor → Tools (Ribbon tab) → Template (Ribbon bar)
In the template settings screen, the data sources that should be used by default when using this template, can be set. For example AHN3 can be selected so that the AHN3 is always used when creating a project based on that template. Changes made are stored in Geo Option items.
Geo Options
Name Default Value Description
NL_BGT true BGT (dataset not complete, more details in roads, water, streetobjects, trees)
HEIGHTMAP_RESOLUTION NORMAL DEM Resolution
SATELLITE_RESOLUTION HIGH Satellite Background Resolution
RISK_ASSESSMENT false Risk Assessment (detect e.g. dangerous objects like LPG stations)
AGRICULTURE true Agriculture (crop fields, grassland, etc)
UNDERGROUND true Underground (soil type)
OWNERSHIP true Ownership (cadastral data)
WATER true Water (rivers, canals, etc)
ZONING false Zoningplan (limitations to buildings)
NL_AHN AHN4 Dutch AHN version
NL_MIN_TREE_HEIGHT 5 Tree Height from AHN Surface (min value in meters)
NL_MAX_TREE_HEIGHT 50 Tree Height from AHN Surface (max value in meters)
DTM_DSM_THRESHOLDS 0.0 0.0 0.0 Apply DSM to DTM Thresholds for Land, Roads and Other.
WORLD_WATER OSM Water (rivers, canals, etc)
OSM_ROADS true Use OpenStreetMap for Roads
OSM_BUILDINGS true Use OpenStreetMap for Buildings
OSM_LANDUSE true Use OpenStreetMap for Landuse
OSM_NEIGHBORHOODS true Use OpenStreetMap for Neighborhoods
IMWA true IMWA Water System constructions such as culverts
BAG3D_GEOMETRIES false Use 3D BAG by tudelft3d for Building Geometries
I3S_GEOMETRIES false Use I3S Scenelayer for Building Geometries (BETA)
NL_TRAFFIC_INWEVA true INWEVA 24h Data
NL_TRAFFIC_NSL true NSL Monitoring
NL_TRAFFIC_NSL_CONVERSION 0.051 NSL Conversion from day to hour values (default 1.22 / 24)
NL_TRAFFIC_INFOMIL true InfoMil Ruleset
NL_ENERGY_LABEL true Address Energy Labels
INTEREST_AREA_MARGIN 500 Default margin around Area of Interest on file drop
TREES true Default Trees from various Sources
