Api session event editor area
Revision as of 13:31, 14 April 2026 by Frank@tygron.nl (talk | contribs)
Api session event editor area Endpoints.
API Endpoints for Area editing.
Name Description
add Add new Area
add_polygons Add polygons to existing Area
append_attribute Appended to existing Area attribute value
duplicate Duplicate existing Area
import Import Area Collection
remove Remove existing Area
remove_attribute Remove attribute from Area
remove_polygons Remove polygons from existing Area
set_active Set Area active
set_attribute Set Area attribute value
set_attributes Set multiple Area attribute values
set_color Set new color of existing Area
set_name Set new name of existing Area
set_polygons Set polygons to existing Area
Additional API Endpoints:
Name Description
add_group Add Group
add_relation Add Relation
add_with_attribute Add With Attribute
generate_border_areas Generate Border Area
generate_inundation_areas Generate Inundation Area
generate_sewer_areas Generate Sewer Area
generate_water_areas Generate Water Area
remove_all_attributes Remove All Attributes
remove_group Remove Group
remove_relations Remove Relations
set_relation Set Relation
Deprecated API Endpoints:
Name Description
remove_filter Use REMOVE_GROUP instead for identical result.
