Api session event editor area
Revision as of 12:04, 1 April 2026 by Frank@tygron.nl (talk | contribs)
Api session event editor area Events.
Area editing.
Name Description
ADD Add new Area
ADD_POLYGONS Add polygons to existing Area
APPEND_ATTRIBUTE Appended to existing Area attribute value
DUPLICATE Duplicate existing Area
IMPORT Import Area Collection
REMOVE Remove existing Area
REMOVE_ATTRIBUTE Remove attribute from Area
REMOVE_POLYGONS Remove polygons from existing Area
SET_ACTIVE Set Area active
SET_ATTRIBUTE Set Area attribute value
SET_ATTRIBUTES Set multiple Area attribute values
SET_COLOR Set new color of existing Area
SET_NAME Set new name of existing Area
Specific Events:
Name Description
ADD_GROUP Add Group
ADD_RELATION Add Relation
ADD_WITH_ATTRIBUTE Add With Attribute
GENERATE_BORDER_AREAS Generate Border Area
GENERATE_INUNDATION_AREAS Generate Inundation Area
GENERATE_SEWER_AREAS Generate Sewer Area
GENERATE_WATER_AREAS Generate Water Area
REMOVE_ALL_ATTRIBUTES Remove All Attributes
REMOVE_GROUP Remove Group
REMOVE_RELATIONS Remove Relations
SET_POLYGONS Set Polygons
SET_RELATION Set Relation
Deprecated Events:
Name Description
REMOVE_FILTER Use REMOVE_GROUP instead for identical result.
