Water balance (Water Overlay)
| Input | Configuration | Result | Output | Configuration | Result | ||
| Water surface | Water area, Surface level prequel | Water surface | Surface last value | ||||
| Rain | Rain m, Rain areas | Evaporated | Evaporation m | ||||
| Building Storage | Water storage m2 | [[Building last storage result type (Water Overlay) | Building last storage]] | ||||
| Sewer Storage | Sewer storage | Sewer last value | |||||
| Sewer Out External | Sewer pump speed | Object flow output | |||||
| Bottom in | Bottom Pressure and Resistance | [[Ground bottom flow result type (Water Overlay) | Ground bottom flow]] | Bottom Out | Bottom Pressure and Resistance | [[Ground bottom flow result type (Water Overlay) | Ground bottom flow]] |
| Breach | Breach | Object flow output | Breach Out | Breach | Object flow output | ||
| Inundated | Inundation area | Surface last value | Land Surface | Surface last value | |||
| Inlet | Inlet | Object flow output | Outlet | Outlet | Object flow output | ||
| Saturated Ground Storage | Saturated Ground Storage | ||||||
| Unsaturated Ground Storage | Unsaturated Ground Storage |
