Water balance (Water Overlay)
| Input | Output | ||
| Water surface | Water area, Surface level prequel | Water surface | |
| Rain | Rain m, Rain areas | Evaporated | Evaporation m |
| Building Storage | Water Storage m2 | ||
| Sewer Storage | Sewer storage | ||
| Sewer Out External | Sewer pump speed | ||
| Bottom in | Bottom Pressure and Resistance | Bottom Out | Bottom Pressure and Resistance |
| Breach | Breach | Breach Out | Breach |
| Inundated | Inundation Area | Land Surface | |
| Inlet | Inlet | Outlet | Outlet |
| Saturated Ground Storage | Saturated Ground Storage | ||
| Unsaturated Ground Storage | Unsaturated Ground Storage |
