Template:Common TQL params
AREA
Item ID
Area with ID
true
Areatype (TQL Param)
AREA_WITH_ATTRIBUTE
Attribute
Area with non zero Attribute value
true
TERRAIN
Item ID
Terrain of Terrain Type with ID
true
TERRAIN_WITH_ATTRIBUTE
Attribute
Terrain is of Terrain Type with non zero Attribute value
true
Terrainmult (TQL Param)
CATEGORY
Category
Category with this value
Buildings of this category
false
CATEGORYMULT
Item ID
Multiply the calculated value with this Category Value of a Building
false
LEVEE
Item ID
Levee with ID
false
FUNCTION
Item ID
Function with ID
false
PANEL
Item ID
Panel with ID
false
FUNCTIONMULT
Item ID
Multiply the calculated value with this Function Value of a Building
false
GRID
Item ID
Grid of Grid Overlay with ID
false
GRID_WITH_ATTRIBUTE
Attribute
Grid of Grid Overlay with non zero Attribute value
false
GRIDTYPE
Overlay type
Grid of Grid Overlay with specified type
true
GRIDVALUE
decimal
Only include Grid Overlay cells that have a value equal to the one specified
true
BUFFER
decimal
Buffer the limiting search polygon with this value.
true
MAXGRIDVALUE
decimal
Only include Grid Overlay cells that have a value smaller than the one specified
true
MINGRIDVALUE
decimal
Only include Grid Overlay cells that have a value larger than or equal to the one specified
true
INDICATOR
Item ID
Indicator with ID
false
LAYERTYPE
Layer
Only include Buildings and Terrains that are part of this layer
true
MAP
Map Type
Only items present in this Map Type
true
NET_LINE
Item ID
Net line with ID
false
NET_TYPE
Net type
Only net items of this net type
false
NET_FUNCTION
Item ID
Net Function with ID
false
NET_LOAD
Item ID
Net Load with ID
false
NET_CLUSTER
Item ID
Net Cluster with ID
true
STAKEHOLDER
Item ID
Stakeholder with ID
Only include Plots that are owned by the stakeholder with this ID
Only include Items that are related to this stakeholder
true
STAKEHOLDERTYPE
Stakeholder Type
Stakeholder Type with this value
Only include Plots that are owned by this type of stakeholder
true
STATE
Timestate
Only include Buildings and Measures that are in this timestate
false
ZONE
Item ID
Zone with ID
true
ZONE_WITH_ATTRIBUTE
Attribute
Zone with non zero Attribute value
true
NEIGHBORHOOD
Item ID
Neighborhood with ID
true
NEIGHBORHOOD_WITH_ATTRIBUTE
Attribute
Neighborhood with non zero Attribute value
true
BUILDING
Item ID
Building with ID
false
ATTRIBUTE
Attribute
The attribute used for Buildings to obtain a value.
false
ATTRIBUTE_MAX
decimal
Only include Buildings that have an attribute value smaller than this value.
false
ATTRIBUTE_MAX
decimal
Only include Buildings that have an attribute value larger than or equal to this value.
false
ATTRIBUTE_MULT
Attribute
Multiply the calculated value with the value of this attribute for a Building
false
RELATION
Relation
Allows to convert a specific selected item to an other item it is related to.
false
OVERLAY
Item ID
Overlay with ID
false
TIMEFRAME
timeframe
Specifies which timeframe to select when processing a particular Grid
false
RESIDENCE
boolean
When true, consider only Buildings that are residences
false
ROAD_SYSTEM
boolean
When true, consider only Buildings that are part of the road system
false
A list of all common TQL params
Allowed clause parameters
Areatype (TQL Param)Terrainmult (TQL Param)| Param | Type | Description | Limits search polygon |
| AREA | Item ID | Area with ID | true |
| AREA_WITH_ATTRIBUTE | Attribute | Area with non zero Attribute value | true |
| TERRAIN | Item ID | Terrain of Terrain Type with ID | true |
| TERRAIN_WITH_ATTRIBUTE | Attribute | Terrain is of Terrain Type with non zero Attribute value | true |
| CATEGORY | Category | Category with this value Buildings of this category |
false |
| CATEGORYMULT | Item ID | Multiply the calculated value with this Category Value of a Building | false |
| LEVEE | Item ID | Levee with ID | false |
| FUNCTION | Item ID | Function with ID | false |
| PANEL | Item ID | Panel with ID | false |
| FUNCTIONMULT | Item ID | Multiply the calculated value with this Function Value of a Building | false |
| GRID | Item ID | Grid of Grid Overlay with ID | false |
| GRID_WITH_ATTRIBUTE | Attribute | Grid of Grid Overlay with non zero Attribute value | false |
| GRIDTYPE | Overlay type | Grid of Grid Overlay with specified type | true |
| GRIDVALUE | decimal | Only include Grid Overlay cells that have a value equal to the one specified | true |
| BUFFER | decimal | Buffer the limiting search polygon with this value. | true |
| MAXGRIDVALUE | decimal | Only include Grid Overlay cells that have a value smaller than the one specified | true |
| MINGRIDVALUE | decimal | Only include Grid Overlay cells that have a value larger than or equal to the one specified | true |
| INDICATOR | Item ID | Indicator with ID | false |
| LAYERTYPE | Layer | Only include Buildings and Terrains that are part of this layer | true |
| MAP | Map Type | Only items present in this Map Type | true |
| NET_LINE | Item ID | Net line with ID | false |
| NET_TYPE | Net type | Only net items of this net type | false |
| NET_FUNCTION | Item ID | Net Function with ID | false |
| NET_LOAD | Item ID | Net Load with ID | false |
| NET_CLUSTER | Item ID | Net Cluster with ID | true |
| STAKEHOLDER | Item ID | Stakeholder with ID Only include Plots that are owned by the stakeholder with this ID Only include Items that are related to this stakeholder |
true |
| STAKEHOLDERTYPE | Stakeholder Type | Stakeholder Type with this value Only include Plots that are owned by this type of stakeholder |
true |
| STATE | Timestate | Only include Buildings and Measures that are in this timestate | false |
| ZONE | Item ID | Zone with ID | true |
| ZONE_WITH_ATTRIBUTE | Attribute | Zone with non zero Attribute value | true |
| NEIGHBORHOOD | Item ID | Neighborhood with ID | true |
| NEIGHBORHOOD_WITH_ATTRIBUTE | Attribute | Neighborhood with non zero Attribute value | true |
| BUILDING | Item ID | Building with ID | false |
| ATTRIBUTE | Attribute | The attribute used for Buildings to obtain a value. | false |
| ATTRIBUTE_MAX | decimal | Only include Buildings that have an attribute value smaller than this value. | false |
| ATTRIBUTE_MAX | decimal | Only include Buildings that have an attribute value larger than or equal to this value. | false |
| ATTRIBUTE_MULT | Attribute | Multiply the calculated value with the value of this attribute for a Building | false |
| RELATION | Relation | Allows to convert a specific selected item to an other item it is related to. | false |
| OVERLAY | Item ID | Overlay with ID | false |
| TIMEFRAME | timeframe | Specifies which timeframe to select when processing a particular Grid | false |
| RESIDENCE | boolean | When true, consider only Buildings that are residences | false |
| ROAD_SYSTEM | boolean | When true, consider only Buildings that are part of the road system | false |
