Template:Common TQL params
Revision as of 17:03, 13 February 2023 by Frank@tygron.nl (talk | contribs)
AREA Item ID Area with ID true Areatype (TQL Param) AREA_WITH_ATTRIBUTE Attribute Area with non zero Attribute value true TERRAIN Item ID Terrain of Terrain Type with ID true TERRAIN_WITH_ATTRIBUTE Attribute Terrain is of Terrain Type with non zero Attribute value true Terrainmult (TQL Param) CATEGORY Category Category with this value
Buildings of this category false CATEGORYMULT Item ID Multiply the calculated value with this Category Value of a Building false LEVEE Item ID Levee with ID false FUNCTION Item ID Function with ID false PANEL Item ID Panel with ID false FUNCTIONMULT Item ID Multiply the calculated value with this Function Value of a Building false GRID Item ID Grid of Grid Overlay with ID false GRID_WITH_ATTRIBUTE Attribute Grid of Grid Overlay with non zero Attribute value false GRIDTYPE Overlay type Grid of Grid Overlay with specified type true GRIDVALUE decimal Only include Grid Overlay cells that have a value equal to the one specified true BUFFER decimal Buffer the limiting search polygon with this value. true MAXGRIDVALUE decimal Only include Grid Overlay cells that have a value smaller than the one specified true MINGRIDVALUE decimal Only include Grid Overlay cells that have a value larger than or equal to the one specified true INDICATOR Item ID Indicator with ID false LAYERTYPE Layer Only include Buildings and Terrains that are part of this layer true MAP Map Type Only items present in this Map Type true NET_LINE Item ID Net line with ID false NET_TYPE Net type Only net items of this net type false NET_FUNCTION Item ID Net Function with ID false NET_LOAD Item ID Net Load with ID false NET_CLUSTER Item ID Net Cluster with ID true STAKEHOLDER Item ID Stakeholder with ID
Only include Plots that are owned by the stakeholder with this ID
Only include Items that are related to this stakeholder true STAKEHOLDERTYPE Stakeholder Type Stakeholder Type with this value
Only include Plots that are owned by this type of stakeholder true STATE Timestate Only include Buildings and Measures that are in this timestate false ZONE Item ID Zone with ID true ZONE_WITH_ATTRIBUTE Attribute Zone with non zero Attribute value true NEIGHBORHOOD Item ID Neighborhood with ID true NEIGHBORHOOD_WITH_ATTRIBUTE Attribute Neighborhood with non zero Attribute value true BUILDING Item ID Building with ID false ATTRIBUTE Attribute The attribute used for Buildings to obtain a value. false ATTRIBUTE_MAX decimal Only include Buildings that have an attribute value smaller than this value. false ATTRIBUTE_MAX decimal Only include Buildings that have an attribute value larger than or equal to this value. false ATTRIBUTE_MULT Attribute Multiply the calculated value with the value of this attribute for a Building false RELATION Relation Allows to convert a specific selected item to an other item it is related to. false OVERLAY Item ID Overlay with ID false TIMEFRAME timeframe Specifies which timeframe to select when processing a particular Grid false RESIDENCE boolean When true, consider only Buildings that are residences false ROAD_SYSTEM boolean When true, consider only Buildings that are part of the road system false
