Elevation (Water Overlay)
The elevation model defines the height of the terrain on and in which the hydrology is modeled. Elevation includes the relief on the surface of dry land, but also the height of the stream beds of water bodies.
By default the elevation model will be derived from data sources relevant to the geographical location of the project area. However, especially in water bodies the level of detail of the elevation model may be insufficient. For these situations it's possible to load in a(n additional) GeoTIFF defining elevations, load in a GeoJSON file with water depths, or manually modify the elevation model.
In addition to the elevation model, the height of constructions is also taken into account. Breaches are also embedded into the resulting Digital Surface Model the Water Module uses for its calculations.
During a session, a number of actions can directly affect the terrain height. Actions such as the creation of levees, or the creation of open water, both affect the topography. Placing or removing constructions also affects the terrain height, in terms of where water can flow.
How to's
- How to import a GeoTIFF to change the elevation model
- How to import a GeoTIFF of waterway depths
- How to import a GeoJSON to change the elevation model
- Levee
- Elevation model
- Breach (Water Overlay)
- Subsidence (Water Overlay)
- Surface model (Water Overlay)
- Elevation model (Water Overlay)
