Elevation (Water Overlay)
Revision as of 14:50, 26 August 2020 by Rudolf@tygron.nl (talk | contribs)
By default the terrain height model will be derived from data sources relevant to the geographical location of the project area. However, especially in water bodies the level of detail of the terrain height may be insufficient. For these situations it's possible to load in a(n additional) GeoTiff of terrain heights, load in a GeoJSON file with water depths, or manually modify the elevation model.
In addition to the base terrain height, the height of constructions is also taken into account. Breaches are also embedded into the resulting Digital Surface Model the Water Module calculates with.
During a session, a number of actions can directly affect the terrain height. Actions such as the creation of levees, or the creation of open water, both affect the topography. Placing or removing constructions also affects the terrain height, in terms of where water can flow.
Template:GeoTiffSpec
How to's
