How to configure the Waterwijzer Overlay to use groundwater results from other calculations
The Waterwijzer Overlay can provide insight into the yield loss in agrarian locations, due to hydrological conditions in the underground. By connecting it to other calculation models, specifically for their computed groundwater levels, it's possible to set up a dynamic model in which actions can directly influence the viability of crops, and thus the resulting expected yields.
Adding subsidence calculations
To account for subsidence, and its effects on groundwater when using the Waterwijzer Overlay, make sure:
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → Waterwijzer Overlay (Left panel)
How to account for subsidence in the Waterwijzer Overlay:
  1. In the Editor, open the list of Overlays.
  2. In the left panel, select the Waterwijzer Overlay, and open its configuration wizard.
  3. Continue to the groundwater steps.
  4. In the step for low groundwater, opt to select an Overlay.
  5. Select the Subsidence Overlay's result for low ground water.
  6. In the step for high groundwater, opt to select an Overlay.
  7. Select the Subsidence Overlay's result for high ground water.
  8. Finish and close the wizard.
  9. If necessary, recalculate the Overlay.
  10. The Waterwijzer Overlay now shows new results.
Using groundwater calculations
To account for dynamically calculated groundwater flow when using the Waterwijzer Overlay, make sure:
How to dynamically calculate groundwater for the Waterwijzer Overlay:
  5. Select the Water Overlay's result for ground watertable.
  7. Select the Water Overlay's result for ground watertable.
