Api session event editor netload set state
API Endpoint: api/session/event/editornetload/set_state/
Description: Set the Net state of a Net Load
0 REQUIRED (NET_LOAD Integer ID or multiple integer values in array [1, 2, 3]) Net Loads
1 REQUIRED (TimeState or multiple values in array [a, b, c]) Timestates
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/set_state/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "NOTHING" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetload/set_state/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "NOTHING", "WAITING_FOR_DATE", "REQUEST_PLOT_OWNER_APPROVAL" ] ]'
JavaScript example POST
 body: '[ 1, "NOTHING" ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/set_state/", options)
