Api session event editor netload generate paths
API Endpoint: api/session/event/editornetload/generate_paths/
Description: Connect Net Loads to an existing Net by adding Net Lines with the provided Net Function. Net Lines are generated with a Search Range for paths to existing Net Nodes and a Merge Range to combine Net Nodes
0 REQUIRED (NET_FUNCTION Integer ID) Net Function
1 REQUIRED (NET_LOAD Integer ID or multiple integer values in array [1, 2, 3]) Net Loads
2 REQUIRED (Floating point number) Search Range
3 REQUIRED (Floating point number) Merge Range
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_paths/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 72, 43 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_paths/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], 16, 45 ]'
JavaScript example POST
 body: '[ 1, 1, 72, 43 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/generate_paths/", options)
