Api session event editor netload set point
API Endpoint: api/session/event/editornetload/set_point/
Description: Set the Location of a Net Load
0 REQUIRED (NET_LOAD Integer ID) Net Load
1 OPTIONAL (Point with crs: EPSG:3857) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetload/set_point/?crs=3857", options)
