Api session event editor netload set node
API Endpoint: api/session/event/editornetload/set_node/
Description: Set the Net Node of a Net Load
0 REQUIRED (NET_LOAD Integer ID) Net Load
1 REQUIRED (NET_NODE Integer ID) Net Node
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/set_node/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/set_node/", options)
