Api session event editor netload add
API Endpoint: api/session/event/editornetload/add/
Description: Add a new Net Load for a Net Type and optionally set as Root Load
0 REQUIRED (Enumeration) Net Type ELECTRICITY, GAS, HEAT, INTERNET or SEWER
1 REQUIRED (true, false) Is Root Load true or false
200 Integer (Net Load ID)
curl 'https://engine.tygron.com/api/session/event/editornetload/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ELECTRICITY", true ]'
JavaScript example POST
 body: '[ "ELECTRICITY", true ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/add/", options)
