Api session event editor geoplugin
Revision as of 10:22, 13 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorgeoplugin/
API Endpoints for Geo Plugin editing.
Name Description
add Add a new Geo Plugin of a Geo Link Type
duplicate Duplicate existing Geo Plugin
remove Remove existing Geo Plugin
set_name Set the name of a Geo Plugin
Additional API Endpoints:
Name Description
add_link Add a Geo Link to a Geo Plugin
add_new_links Add a new Geo Link to a Geo Plugin with a provided name
remove_link Remove a Geo Link from a Geo Plugin
remove_source Remove the Source of a Geo Plugin
set_crs Override the CRS used by a Geo Plugin to transform data from its Source
set_force_xy Override the CRS's Force XY parameter, used by a Geo Plugin to transform data from its Source
set_id_attribute Set the ID Attribute used by a Geo Plugin to retrieve unique IDs of features obtained from its Source
set_image Set the image of a Geo Plugin
set_layer_name Set the Layer used by a Geo Plugin to obtain data from its Source
set_name_attribute Set the Name Attribute used by a Geo Plugin to retrieve names of features obtained from its Source
set_new_project Set whether a Geo Plugin is active in the New Project Wizard
set_source Set the Source of a Geo Plugin, used to obtain data or features
