Api session event editor geoplugin set crs
API Endpoint: api/session/event/editorgeoplugin/set_crs/
Description: Override the CRS used by a Geo Plugin to transform data from its Source
0 REQUIRED (GEO_PLUGIN Integer ID or multiple integer values in array [1, 2, 3]) Geo Plugins
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) CRS Names
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "CRS Name 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "CRS Name 1", "CRS Name 2", "CRS Name 3" ] ]'
JavaScript example POST
 body: '[ 1, "CRS Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/set_crs/", options)
