Api session event editor geoplugin set name attribute
API Endpoint: api/session/event/editorgeoplugin/set_name_attribute/
Description: Set the Name Attribute used by a Geo Plugin to retrieve names of features obtained from its Source
0 REQUIRED (GEO_PLUGIN Integer ID or multiple integer values in array [1, 2, 3]) Geo Plugins
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Name Attributes
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_name_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Name Attribute 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_name_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Name Attribute 1", "Name Attribute 2", "Name Attribute 3" ] ]'
JavaScript example POST
 body: '[ 1, "Name Attribute 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/set_name_attribute/", options)
