Api session event editor geoplugin add
API Endpoint: api/session/event/editorgeoplugin/add/
Description: Add a new Geo Plugin of a Geo Link Type
| 0 | REQUIRED | (Enumeration) | Geo Link Types | AREA, BUILDING, ROAD, STREET_OBJECT, TERRAIN_HEIGHT or WATER_BOTTOM |
| 200 | Integer (Geo Plugin) |
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"AREA"'JavaScript example POST
body: '"AREA"'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/add/", options)
