Api session items geoplugins
API Endpoint: /api/session/items/geoplugins/
Edit items with events described at Api session event editor geoplugin.
Default Query:
https://engine.tygron.com/api/session/items/geoplugins/?token=API_TOKEN
Example Response:
  "crs" : "urn:ogc:def:crs:EPSG::28992",
  "forceXY" : true,
  "geoLinkIDs" : [ 2264, 2265, 2266, 2267 ],
  "id" : 0,
  "idAttribute" : "nr",
  "layerName" : "natura2000:natura2000",
  "linkType" : "AREA",
  "name" : "Natura2000",
  "nameAttribute" : "naam_n2k",
  "newProject" : false,
  "sourceID" : 103,
  "version" : 1
  "crs" : "",
  "forceXY" : true,
  "geoLinkIDs" : [ 1000259, 1000260 ],
  "id" : 1000000,
  "idAttribute" : "",
  "layerName" : "",
  "linkType" : "BUILDING",
  "name" : "Building Geo Plugin",
  "nameAttribute" : "",
  "newProject" : true,
  "sourceID" : -1,
  "version" : 2
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/geoplugins/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/geoplugins/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/geoplugins/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/geoplugins/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/geoplugins/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/geoplugins/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/geoplugins/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/geoplugins/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/geoplugins/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/geoplugins/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/geoplugins/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/geoplugins/?f=ZIPSMILE&token=API_TOKEN
Api Model AbstractGeoPlugin
API Model description of AbstractGeoPlugin
Name Type Description
crs String
forceXY boolean
id int
linkType GeoLinkType Geo LinkType
name String
newProject boolean
version int
Api Model GeoLinkType
API Enumeration description of GeoLinkType
Name Description
AREA
BUILDING
ROAD
TERRAIN_HEIGHT
WATER_BOTTOM
STREET_OBJECT
Api Model GeoPlugin
API Model description of GeoPlugin
crs String
forceXY boolean
geoLinkIDs int[] Geo Links ID
id int
idAttribute String
layerName String
name String
nameAttribute String
newProject boolean
sourceID int Source ID
version int
Api Model HeightPlugin
API Model description of HeightPlugin
crs String
forceXY boolean
id int
name String
newProject boolean
sourceIDs int[] Sources ID
version int
