Api session event editor geoplugin remove link
API Endpoint: api/session/event/editorgeoplugin/remove_link/
Description: Remove a Geo Link from a Geo Plugin
| 0 | REQUIRED | (GEO_PLUGIN Integer ID or multiple integer values in array [1, 2, 3]) | Geo Plugins | |
| 1 | REQUIRED | (GEO_LINK Integer ID or multiple integer values in array [1, 2, 3]) | Geo Links |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/remove_link/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/remove_link/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/remove_link/", options)
