Api session event editor geoplugin set id attribute
API Endpoint: api/session/event/editorgeoplugin/set_id_attribute/
Description: Set the ID Attribute used by a Geo Plugin to retrieve unique IDs of features obtained from its Source
| 0 | REQUIRED | (GEO_PLUGIN Integer ID or multiple integer values in array [1, 2, 3]) | Geo Plugins | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Name Attributes |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_id_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Name Attribute 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_id_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Name Attribute 1", "Name Attribute 2", "Name Attribute 3" ] ]'JavaScript example POST
body: '[ 1, "Name Attribute 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/set_id_attribute/", options)
