Combo Overlay tutorial
Revision as of 13:51, 16 October 2026 by Len@tygron.com (talk | contribs) (Undo revision 96052 by Len@tygron.com (talk))
Prerequisites
  • This tutorial will take approximately 45 minutes.
  • This tutorial relies on base knowledge about the editor interface and the creation of Overlays. If you have not yet followed the tutorials related to those subjects please do so first.
  • This tutorial can be followed with any project of any arbitrary location, preferably with both roads and traintracks.
Preparations
Introduction to the Combo Overlay
The Combo Overlay is a Grid Overlay which allows for the creation of custom spatial calculation models. It is comparable to raster calculators which can be found in other GIS packages such as QGIS. The principle on which it operates is that for each grid cell, other Grid Overlays may provide values, and the combo Overlay uniformly applies a (simple or complex) formula to compute a new resulting value for that grid cell, and does so for all grid cells.
Creating a simple masking calculation
To get started with a Combo Overlay, it is basically always necessary to have some other Grid Overlay in the same Project to run a calculation on.
Add a Traffic Noise Overlay.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → Environmental (Dropdown) → Traffic Noise
Adding the Traffic Noise Overlay from the ribbon.
This Traffic Noise Overlay will serve as the primary input to work with. It computes results based on built-in formulas for noise from traffic. Although it's possible to tweak the inputs and the legend of the resulting Overlay, the principles of the calculation and the results thereof are immutable.
The traffic noise overlay is a standard calculation model.
Add a Combo Overlay.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → Custom (Dropdown) → Combo
Adding the Combo Overlay from the ribbon.
The Combo Overlay will, by itself, not show any significantly relevant results. This is because no inputs have yet been set, nor has a relevant formula been entered.
The default results of the Combo Overlay are uniform before inputs and are irrelevant.
The Combo Overlay accepts a set of inputs, which are Grid Overlays.
Set Grid Overlay A to the added Traffic Noise Overlay.
Set the input A to the Traffic Noise Overlay.
Next, set the formula to:
A
This formula will directly output A.
Then, click on ""Update now" to recalculate the Overlays.
The result is that for each grid cell, the value of the input Overlay A, which is set to the Traffic Noise Overlay, is used directly as the result.
Notice that the legend of the Traffic Noise Overlay is directly applied as well. This is because the legend of the first input is automatically read out by the Combo Overlay as the default legend for the Combo Overlay itself.
The results of the Combo Overlay directly outputting the results of the Traffic Noise Overlay.
Just like with the Traffic Noise Overlay itself, it is possible to click on any location in the 3D Visualization and see the exact value calculated there.
The hover panel will display the name of the Combo Overlay, and the value of that location.
Using the Combo Overlay, it is possible to manipulate those calculated values. One often used principle is to "mask" data, which basically means to explicitly obscure or let through some values.
Modify the formula of the combo Overlay, so that it reads as follows:
IF(GT(A, 55), A, NO_DATA)
This formula will remove values lower than 55 from the results.
The formula now contains two logical operations, as well as a NO_DATA constant. The formula can be read as follows:
If ( IF ) it is true that A is greater than 55 ( GT ), in that case we use the value A. Otherwise, we return the value of NO_DATA, which is a constant meaning no value exists at that point.
Click on "Update now" to recalculate the Overlays.
The results of the Combo Overlay have now changed. Only in the places where the Traffic Noise Overlay computed a noise level of more than 55dB have results now been retained. In all other locations, the results have been discarded.
Only results in locations with significant noise, greater than 55.
Rasterizing and combining data
Combo Overlays are, in and of themselves, effective tools for manipulating data. Their effectiveness is determined by the inputs provided to them. Therefore, it is also important to know how to turn other data in the Tygron Platform into Grid Overlays as well.
To try this out, information about train tracks will be added to the Combo Overlay, or more specifically information about the proximity of train tracks.
Train tracks have a number of trains running on them. This can be visualized using an Average Overlay.
Add an Average Overlay.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → Distance (Left panel) → Avg & Interpolation
Adding an Average Overlay from the ribbon.
Set the "Input" to "Attribute: Specific Layer", and the layer to "BUILDINGS". This will ensure the Average Overlay is specifically geared towards consulting data from Buildings.
The Average Overlay will only consult the Buildings in the Project.
Next, set the "Attribute" to "NUM_TRAINS". The NUM_TRAINS attribute indicates how many trains move over nearby tracks per hour, as rasterized onto buildings.
The Average Overlay will refer to the NUM_TRAINS Attribute.
The "Cell averaging distance", which is set to 100m by default, can be left as-is.
Finally, click on "Update now" to have the Average Overlay recalculate.
The result will be an Overlay which highlights train tracks, with a radius of 100m. Or in terms more practical for this setup: for any given grid cell, the Average Overlay indicates whether a train track is within 100m.
The results of the Average Overlay when configured.
Any cell with a value of 0 only has cells in a 100m radius with 0's. If any cell within that radius would feature a train track, the computed (average) value would be slightly more than 0. This value serves as an effective filter to identify which cells are "near a train track".
Now, switch back to the Combo Overlay by selecting it in the left panel.
Re-select the Combo Overlay.
Add a second input for the calculation. For Grid Overlay B, select the added Average Overlay.
Add the Average Overlay to the list of inputs.
Modify the formula of the Combo Overlay, so that it reads as follows:
IF(GT(A, 55), ADD(A, IF(GT(B, 0), 5, 0)), NO_DATA)
This formula will increase the result, based on another input's value.
Instead of simply resulting in the value of A, the calculation will result in the combined values of A and either 5 or 0, depending on whether B has a value greater than 0. Since B will have a value slightly more than 0 when near a train track, this formula will now add an additional 5dB to the total result when near a train track.
The results are now subtly different, in that for all locations within 100m of the train tracks the noise level is computed as 5dB louder than otherwise.
The results when adding train noise to the masked results.
Werken met de Tygron.AI Project Agent
In het vorige onderdeel zijn de Combo Overlays handmatig opgebouwd. Dezelfde stappen kunnen ook via prompts aan de Tygron.AI Project Agent worden uitgevoerd.
In dit onderdeel gebruiken we AI om:
  • een Combo Overlay aan te maken en te configureren;
  • invoer en rekenregels in te stellen;
  • data met een Average Overlay te rasteriseren;
  • verschillende databronnen in één berekening te combineren en de berekening verder aan te passen.
Ga naar de Tygron.AI project agent:
File
Stap 1: Een Combo Overlay maken
Vraag de Tygron.AI Project Agent om een Combo Overlay te maken op basis van de Traffic Noise Overlay, waarbij alleen waarden boven 55 dB worden weergegeven.
Voorbeeld prompt:
Maak een Combo Overlay op basis van de Traffic Noise Overlay en toon alleen waarden boven 55 dB.
Stap 2: Spoorwegen toevoegen aan de berekening
Vraag de Tygron.AI Project Agent om met een Average Overlay te bepalen welke locaties binnen 100 meter van een spoorlijn liggen en deze als extra invoer voor de Combo Overlay te gebruiken.
Voorbeeld prompt:
Bepaal met een Average Overlay welke locaties binnen 100 meter van een spoorlijn liggen en gebruik deze als extra input voor de Combo Overlay.
Stap 3: De berekening uitbreiden
Vraag de Tygron.AI Project Agent om binnen 100 meter van een spoorlijn 5 dB aan het resultaat toe te voegen.
Voorbeeld prompt:
Pas de Combo Overlay aan zodat binnen 100 meter van een spoorlijn 5 dB wordt toegevoegd.
Presentation
When creating custom Overlays, be it with Average Overlays or Combo Overlays, it is very important to provide information on what the user is looking at. Especially for the relevant results but where possible also for intermediate steps.
Rename the Average Overlay, highlighting the train tracks, to "Train track vicinity".
Renamed Overlay for the vicinity of train tracks.
Rename the first Combo Overlay to "Combined Noise".
Renamed Overlay for combined noise.
Rename the second Combo Overlay to "Significant Noise".
Renamed Overlay for noise if the noise is significant.
Select the "Train Track vicinity" Overlay (the created Average Overlay), and in the right panel switch to the "Legend" tab.
The "Legend" tab.
Ensure "Has Custom Legend" is checked. This allows setting which values resulting from the Overlay's calculation conform to which results. Modifying these values allow for creating a clearer or more relevant visualization of the data.
The option for a Custom Legend
Select 3 of the entries, and remove them.
Select the entries, then click remove at the bottom of the right panel.
Change the first entry's color to a dark-grey or black, set the name to "No", and ensure the value is 0.
Notice this immediately changes the visualization as well. Although the results of the calculation have not changed, and in fact no new calculation was performed, the way the results are shown are dynamically updated.
The changed entry, and the partially changed visualization to match.
Change the second entry's color to light-red, set the name to "Yes", and ensure the value is set to around 0,1 .
The changed entry, and the fully changed visualization to match.
Notice the Overlay now does not show a progressive coloring, but more of a hard-line yes-or-no indication of what is or isn't near the tracks. This provides a clear indication of proximity to the tracks and aligns with how the Combo Overlay uses the data. This makes the Overlay clearer and more useful to the user who eventually inspects and uses the Overlay or the Project it is part of.
The same principles of making the results more interpretable can apply to Combo Overlays. However, the necessity to tweak these depends strongly on how closely the results match the intent of legend of the first input Overlay.
Final assignments
  • Add an additional Average Overlay, which only highlights the location of the train track and not the region around it.
  • Add an additional Combo Overlay, which shows a color based on whether an area is away from the train tracks, near the train tracks, or itself train tracks.
    Tip: You can add the results of multiple GT() operations together in a Combo Overlay's formula.
Final notes
  • The editor interface will generally present the first 3 inputs (A, B, and C) of the Combo Overlay. However, a total of 10 inputs can be added and used, by switching to the "inputs" tab.
Tutorial completed
Congratulations. You have now completed this tutorial. In it, you have learned how to create Combo Overlays, and how to use Average Overlays to rasterize data for use in the Combo Overlay.
