How to manually edit a network
Revision as of 09:22, 9 October 2026 by Frank@tygron.nl (talk | contribs)
How to manually edit a network:
  1. Hover over Networks in the ribbon.
  2. Select the option 'Edit Network'.
  3. Select an Active Net Type. If none are available, click on the 'Activate Net Type' link.
  4. Optionally select a Net Function for newly added Net Lines.
  5. Select a draw option: 'Add', 'Remove' or 'Move'.
  6. Click in the 3D Visualization to add Net Nodes connected by Net Lines of the selected Net Function.
  7. Once ready, click on the 'Done' button.
