Api session event editor netline add for points
API Endpoint: api/session/event/editornetline/add_for_points/
Description: Connect start and end Points with one or more Net Lines of a specified Net Function. Net Nodes are created for both Points. Optionally connect the Points using the road system and specify the merge distance for existing Net Nodes
| 0 | REQUIRED | (NET_FUNCTION Integer ID or multiple integer values in array [1, 2, 3]) | Net Functions | |
| 1 | REQUIRED | (Point 3D with crs: EPSG:3857 or multiple values in array [a, b, c]) | Start Point | |
| 2 | REQUIRED | (Point 3D with crs: EPSG:3857 or multiple values in array [a, b, c]) | End Point | |
| 3 | OPTIONAL | (true, false) | Connect via Roads (false = connect direct between Points) | |
| 4 | OPTIONAL | (Floating point number) | Node merge distance (optional, default: 1.0m) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetline/add_for_points/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658652.0206101331, 6799378.385433341, -0.41 ]
"type" : "Point",
"coordinates" : [ 658682.0346451474, 6799413.922866575, -1.05 ]
'Curl example multi item POST
[ [ 1, 2, 3 ], [ {
"type" : "Point",
"coordinates" : [ 658687.7272421563, 6799368.632602594, -0.87 ]
"type" : "Point",
"coordinates" : [ 658791.7304210619, 6799318.30136145, -0.85 ]
"type" : "Point",
"coordinates" : [ 658711.7709528896, 6799340.195981327, -1.69 ]
"type" : "Point",
"coordinates" : [ 658725.9155541309, 6799414.980172976, -1.55 ]
"type" : "Point",
"coordinates" : [ 658798.5875236501, 6799357.586987822, -0.21 ]
"type" : "Point",
"coordinates" : [ 658669.1146425208, 6799399.843326472, -0.36 ]
'JavaScript example POST
body: '[ 1, { "type" : "Point", "coordinates" : [ 658652.0206101331, 6799378.385433341, -0.41 ]}, { "type" : "Point", "coordinates" : [ 658682.0346451474, 6799413.922866575, -1.05 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/add_for_points/?crs=3857", options)
