Api session event editor netnode set location
API Endpoint: api/session/event/editornetnode/set_location/
Description: Set Location
0 REQUIRED (Enumeration) Network type ELECTRICITY, GAS, HEAT, INTERNET or SEWER
1 REQUIRED (NET_NODE Integer ID) Net Node
2 REQUIRED (Point 3D with crs: EPSG:3857) Location Point
3 OPTIONAL (Floating point number) Node merge distance (optional, default: 1.0m)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetnode/set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ "ELECTRICITY", 1, {
 "type" : "Point",
 "coordinates" : [ 658700.564413842, 6799398.068159523, -1.83 ]
Curl example multi item POST
 "type" : "Point",
 "coordinates" : [ 658778.4742222639, 6799318.59532487, -1.36 ]
JavaScript example POST
 body: '[ "ELECTRICITY", 1, { "type" : "Point", "coordinates" : [ 658700.564413842, 6799398.068159523, -1.83 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetnode/set_location/?crs=3857", options)
