Api session event editor netline insert point
API Endpoint: api/session/event/editornetline/insert_point/
Description: Insert a new Net Node in an existing Net Line, potentially splitting the Net Line into two parts. Also specify at what distance the new Net Nodes are merged with existing Net Nodes
| 0 | REQUIRED | (NET_LINE Integer ID) | Net Line | |
| 1 | REQUIRED | (Point 3D with crs: EPSG:3857) | Inserted Node Point | |
| 2 | OPTIONAL | (Floating point number) | Node merge distance (optional, default: 1.0m) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetline/insert_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658749.6717927756, 6799378.003765303, -0.94 ]
'Curl example multi item POST
[ 1, {
"type" : "Point",
"coordinates" : [ 658639.8428377013, 6799306.978093399, -0.63 ]
'JavaScript example POST
body: '[ 1, { "type" : "Point", "coordinates" : [ 658749.6717927756, 6799378.003765303, -0.94 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/insert_point/?crs=3857", options)
