Api session event editor netline remove repeated
API Endpoint: api/session/event/editornetline/remove_repeated/
Description: Remove Net Lines and optionally remove connected Net Nodes linked to only one other Net Line of the same Net Type
| 0 | REQUIRED | (NET_LINE Integer ID or multiple integer values in array [1, 2, 3]) | Net Lines | |
| 1 | REQUIRED | (true, false) | Is repeated removal | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetline/remove_repeated/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetline/remove_repeated/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], true ]'JavaScript example POST
body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/remove_repeated/", options)
