Api session event editor netline insert and add for points
API Endpoint: api/session/event/editornetline/insert_and_add_for_points/
Description: Insert one Point into the first Net Line and a second Point into the Second Net Line. Potentially connect these two Points with a new Net Line with a specified Net Function. Net Nodes are created for start and end Point. Optionally connect the two Net Nodes using the road system. Also specify at what distance the new Net Nodes are merged with existing Net Nodes
| 0 | REQUIRED | (NET_FUNCTION Integer ID) | Net Function | |
| 1 | REQUIRED | (Integer number) | First Net Line | |
| 2 | REQUIRED | (Point 3D with crs: EPSG:3857) | Start Point | |
| 3 | REQUIRED | (Integer number) | Second Net Line | |
| 4 | REQUIRED | (Point 3D with crs: EPSG:3857) | End Point | |
| 5 | OPTIONAL | (true, false) | Connect via Roads (false = connect direct between Points) | |
| 6 | OPTIONAL | (Floating point number) | Node merge distance (optional, default: 1.0m) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetline/insert_and_add_for_points/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, {
"type" : "Point",
"coordinates" : [ 658657.6043900237, 6799347.590565161, -1.6 ]
}, 1, {
"type" : "Point",
"coordinates" : [ 658670.9564128512, 6799408.2660360625, -1.87 ]
'Curl example multi item POST
[ 1, 1, {
"type" : "Point",
"coordinates" : [ 658717.1159847744, 6799449.866489242, -1.62 ]
}, 1, {
"type" : "Point",
"coordinates" : [ 658714.0301261961, 6799391.589534323, -0.69 ]
'JavaScript example POST
body: '[ 1, 1, { "type" : "Point", "coordinates" : [ 658657.6043900237, 6799347.590565161, -1.6 ]}, 1, { "type" : "Point", "coordinates" : [ 658670.9564128512, 6799408.2660360625, -1.87 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/insert_and_add_for_points/?crs=3857", options)
