Hydrological attributes of buildings (Water Overlay)
Revision as of 14:01, 15 July 2026 by Frank@tygron.nl (talk | contribs)
Beyond acting as hydraulic structures, buildings may have additional attributes that influence the hydrologic model. These attributes are stored and used on a grid cell level. This is different from the hydraulic structure attributes, which are stored and used on an object level.
These attributes can be changed individually per Building or per building's function. In most cases, these attributes already exist as a Function Value.
Besides influencing Water Overlay calculations, building attributes—specifically building height—also affect the interpretation of the elevation model.
  • In contrast with hydraulic structures, which can only behave as a single hydraulic object, buildings can have all of the above effects on the hydrological model simultaneously.
  • Attributes which are connected to a function value can not be redefined using a different attribute name.
API Endpoints
