How to change properties of a traffic unit
Revision as of 12:01, 15 July 2026 by Frank@tygron.nl (talk | contribs)
Existing units can be changed by selecting them in the left panel of the Unit Data Overrides Panel. The characteristics of the existing units are displayed and can be edited on the detail panel on the right side of the editor main view.
How to change units:
  1. Select Current Situation.
  2. Hover Buildings on the ribbon bar.
  3. Select Show Traffic Units in the popup.
  4. In the left panel, search for the unit to be changed in the list of unit data overrides.
  5. Edit the given options on the right panel if desired
Name
Unit Name Field
In the "Name" field, a specific name for the unit can be entered, replacing the default naming. Please note that the default name of a unit often refers to the actual type of the unit.
Active in Simulation
Active in Simulation checkbox
Checking or unchecking this box determines whether the selected unit is visible in the 3D Visualization.
Available Unit Colors
Units of this type are displayed in the 3D Visualization using these colors.
