Api session event editor unitdataoverride set active
API Endpoint: api/session/event/editorunitdataoverride/set_active/
Description: Set whether a Unit Data (Override) is active
0 REQUIRED (UNIT_DATA_OVERRIDE Integer ID or multiple integer values in array [1, 2, 3]) Unit Data Overrides
1 REQUIRED (Boolean or multiple boolean values in array [true, false, true]) Active array
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorunitdataoverride/set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorunitdataoverride/set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorunitdataoverride/set_active/", options)
