Api session event editor unitdataoverride add color
API Endpoint: api/session/event/editorunitdataoverride/add_color/
Description: Add a new color to a Unit Data Override's available unit colors
0 REQUIRED (UNIT_DATA_OVERRIDE Integer ID) Unit Data Override
1 REQUIRED (TColor) Color
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorunitdataoverride/add_color/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "argb" : -65536
JavaScript example POST
 body: '[ 1, { "argb" : -65536} ]'
fetch("https://engine.tygron.com/api/session/event/editorunitdataoverride/add_color/", options)
