How to select specific input data for AI Inference
Revision as of 06:45, 9 July 2026 by Maxim@tygron.com (talk | contribs)
It is possible to mask the image layer of a satellite input in a Combo Overlay. This way you can specifically in- or exclude certain areas from the Inference Overlay. Below you will find some examples, which require that you already have a regular inference overlay set up.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar)
Exclude open water areas from an Inference Overlay
To avoid detecting foliage on open water, these areas can be excluded from the Inference Overlay. In case you would like to exclude areas such as open water, or already existing BGT trees, you can use the following steps.
How to exclude open water from an Inference Overlay:
  1. Add an Average Overlay, we will use this to assign water areas.
  2. With this overlay selected, set the input options to "Attribute: Specific Layer" and "Terrains".
  3. Because we want a sharp distinction between water and land, we set the cell averaging distance to 0 meters.
  4. As attribute to look for, we select "WATER".
  5. Select finally "Update Now", and you have created an overlay that displays all open water areas.
  6. Now add a Combo Overlay.
  7. Select the Original Satellite overlay as input for Grid A.
  8. Select the Avg Water Terrains overlay as input for Grid B.
  9. Enter the following formula: "IF(GT(B, 0), NO_DATA, A)". This formula checks whether a point is in a water area. If so, it returns no data, else it returns the satellite image.
  10. Select again "Update Now".
  11. Now use this new combo overlay with a filtered satellite image as input for your inference overlay, and update. You have now excluded open water areas from your inference overlay.
Only include private yards, and exclude the rest from an Inference Overlay
To improve a heat stress calculation, inference can be used to gain data of foliage in private gardens. For this you can mask all data except private yards from the satellite image.
How to only include private yards, and exclude the rest from an Inference Overlay:
  1. Add an Average Overlay, we will use this to assign private yards.
  2. With this overlay selected, set the input options to "Attribute: Specific Layer" and "Buildings".
  3. Because we want a margin all around to look for foliage at the edges of the private Yards, we set the cell averaging distance to 3,5 meters.
  4. As attribute to look for, we select "PRIVATE_YARD".
  5. Select finally "Update Now", and you have created an overlay that displays all private yard areas/ gardens.
  8. Select the Avg Private Yards overlay as input for Grid B.
  9. Enter the following formula: "IF(GT(B, 0), A, NO_DATA)". This formula checks whether a point is in a private yard. If so, it returns the satellite image, else it returns no data.
  11. Now use this new combo overlay with a filtered satellite image as input for your inference overlay, and update. You have now excluded everything but private yards from your inference overlay.
Rasterize only private yards, based on an Attribute, and exclude the rest from an Inference Overlay
You can also rasterize input for a combo overlay based on a single attribute. Using only an attribute as input, is much faster, as it avoids having to set up areas in an average overlay based on that attribute first. You will, however, lack the option to set up an averaging distance.
  1. Add a Combo Overlay.
  2. Select the Original Satellite overlay as input for Grid A.
  3. Click on 'Select more Input or Attribute'.
  4. Ensure that for input 'Attribute: Specific Layer' and 'Buildings' is selected.
  5. Select or enter 'PRIVATE_YARD' as attribute.
  6. Enter the following formula: "IF(GT(ATTRIBUTE, 0), A, NO_DATA)". This formula checks whether a point is has a value for the attribute PRIVATE_YARD. If so, it returns the satellite image, else it returns no data.
  7. Select again "Update Now".
  8. Now use this new combo overlay with a filtered satellite image as input for your inference overlay, and update. You have now excluded everything but private yards from your inference overlay, based on the attribute PRIVATE_YARD.
  • The detected foliage overlay can be used to import as trees or foliage areas into your project.
  • The Combo Overlay only accepts a satellite image as input in Grid A.
  • You can combine multiple masking overlays; for example you can look for only private yards, but exclude already existing BGT trees.
  • When using only an attribute for input, in stead of an average overlay based on that attribute, it is not possible to implement a so called averaging distance.
