How to detect foliage using an Inference Overlay
How to detect foliage based on an Inference Overlay:
- First add a Satellite Overlay. This will be used as input for the Inference Overlay.
- Add an Inference Overlay
- With the Inference Overlay added and selected, click on Select Neural Network.
- In the selection panel, select the RCNN named foliage.onnx and click select.
- Now select Use A (Input A:RGB) and select the previously added Satellite Overlay.
- Make sure the Grid cell size is between 25-50cm, can be adjusted by selecting (Change Grid).
- Finally select Update Now and see the results.
Labeled features on 0.25m satellite image after calculation.
- The detected foliage overlay can be used to import as trees or foliage areas into your project.
