Scenario
Revision as of 13:43, 8 July 2026 by Frank@tygron.nl (talk | contribs)
Stakeholders and Scenarios
A scenario is an Item that stores a series of settings, actions and events that can be activated automatically. For example, a scenario can:
By default, a project in the Tygron Platform always consists of at least one scenario.
When you have multiple Scenarios, for example with two different designs for your Project, you can switch between them from the ribbon bar in the editor. Currently, only one scenario can be active at the same time. Actions taken in a different scenario are reverted.
Limit Map
Scenarios can be limited to a specific part of the map by setting the 'Limit Calculation Scope' to 'Measure Neighborhoods' in the Editor. This limits calculations to only those Neighborhoods covered by measures. Using the margin attribute a margin can be added around the Neighborhoods.
The attributes and description of an active Scenario are persistent (not reset) when stopping the testrun. This allows users to store attributes for later comparison between Scenario's.
