Api session event editor activate testrun
API Endpoint: api/session/event/editor/activate_testrun/
Description: Start or stop a Scenario Testrun
| 0 | REQUIRED | (true, false) | True to start the Scenario Testrun, false to stop | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editor/activate_testrun/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'JavaScript example POST
body: 'true'
fetch("https://engine.tygron.com/api/session/event/editor/activate_testrun/", options)
