How to change Events fired by a Scenario
Select Events of a Scenario in the overview panel
Add & Remove Event buttons (right panel)
Select and unfold a Scenario in the Scenario Overview and select the Events child to add, edit and remove Server Events that trigger upon activation.
This section manages Server Events that are fired when the Scenario is activated. Use the 'Add Event' button at the bottom of the right panel to assign events to the Scenario. Then the desired event can be selected from a list on the Bottom Panel. The selection can be confirmed with the 'Commit' button, or cancelled with the 'Cancel' button.
How to add events to a scenario:
  1. Select Multi-Scenario → Scenarios
  2. Select scenario to have events added to
  3. Select Event Bundles from the selected Scenario
  4. Select 'Add event' on the bottom of the right panel
  5. Select the newly added event on the right panel
  6. Select the desired server event from the bottom panel
  7. Confirm the selection with the 'Commit' button, or use the 'Cancel' button to clear the selection
Editing a Scenario Event in Bottom Panel and confirming with 'Commit'
