How to configure an intro Cinematic for a Stakeholder and a Scenario
Stakeholder properties (right panel)
Main article: Stakeholders
Selecting the arrow next to 'Stakeholders' on the left panel opens up the stakeholder section, containing the names of all active stakeholders in the project. Here the stakeholder properties can be set up per scenario. The following properties can be adjusted:
Start with Cinematic
Main article: Cinematics
Each stakeholder can have a tailored cinematic at the start of a scenario to explain its specific details. These cinematics must be created first, before they are available for selection from the drop down menu on the right panel.
How to change the scenario starting cinematic for a stakeholder:
  1. Ensure a proper cinematic is available.
  2. Select Multi-Scenario → Scenarios.
  3. Select the Scenario to have the stakeholder cinematic changed from.
  4. Select on the left panel the affected Stakeholder from the Stakeholder list of the selected scenario.
  5. Select on the right panel the desired cinematic from the drop down menu.
  6. Mark the check box 'Start with Cinematic' to activate the cinematic at the start of the scenario
