Api session items scenarios
API Endpoint: /api/session/items/scenarios/
Edit items with events described at Api session event editor scenario.
Default Query:
https://engine.tygron.com/api/session/items/scenarios/?token=API_TOKEN
Example Response:
  "attributes" : {
    "INDICATORS" : [ 0.0, 0.0 ]
  "description" : "",
  "events" : [ ],
  "id" : 0,
  "limitNeighborhoodIDs" : [ ],
  "limitType" : "DEFAULT",
  "maquetteOverride" : null,
  "name" : "Scenario",
  "restartTestrun" : true,
  "version" : 2
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/scenarios/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/scenarios/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/scenarios/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/scenarios/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/scenarios/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/scenarios/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/scenarios/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/scenarios/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/scenarios/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/scenarios/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/scenarios/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/scenarios/?f=ZIPSMILE&token=API_TOKEN
Api Model CodedEvent
API Model description of CodedEvent
Name Type Description
id int
parameters Object[]
Api Model LimitType
API Enumeration description of LimitType
Name Description
DEFAULT
NEIGHBORHOODS
MEASURE_NEIGHBORHOODS
Api Model Scenario
API Model description of Scenario
attributes Map<String,double[]>
description String
events CodedEvent[]
id int
limitNeighborhoodIDs int[] Neighborhoods ID
limitType LimitType
maquetteOverride Map<String,double[]>
name String
restartTestrun boolean
version int
