Geo Option
Geo Option in relation to Sources and Geo Plugins
Geo Options are items that store particular settings used by the Tygron Platform when generating a new project.
New Project Wizard
While selecting new Project's area, advanced options can be accessed.
When choosing the location of the project area during the New Project Wizard, in the second panel of the wizard, the default mode for data selection is Selection. When this option is checked, the Tygron Platform will acquire datasets from a variety of open datasets that are linked to the selected area. Find an overview on which data is used to create a new 3D model on the Project Sources page. The Advanced Options panel can be found above the selection option. When you open this panel the list of a few of the open datasets is displayed. You can choose to include or excluded specific data sources in your project creation.
Editor
Editor → Tools (Ribbon tab) → Template (Ribbon bar)
In the template settings screen, the data sources that should be used by default when using this template, can be set. For example AHN3 can be selected so that the AHN3 is always used when creating a project based on that template. Changes made are stored in Geo Option items.
Values
Name Default Value Description
AGRICULTURE true Agriculture (crop fields, grassland, etc)
BAG3D_GEOMETRIES false Use 3D BAG by tudelft3d for Building Geometries
DTM_DSM_THRESHOLDS 0.0 0.0 0.0 Apply DSM to DTM Thresholds for Land, Roads and Other.
HEIGHTMAP_RESOLUTION NORMAL DEM Resolution
I3S_GEOMETRIES false Use I3S Scenelayer for Building Geometries (BETA)
IMWA true IMWA Water System constructions such as culverts
INTEREST_AREA_MARGIN 500 Default margin around Area of Interest on file drop
NL_AHN AHN4 Dutch AHN elevation model version
NL_BGT true BGT (provides more details in roads, water, streetobjects, trees)
NL_ENERGY_LABEL true Address Energy Labels
NL_MAX_TREE_HEIGHT 50 Tree Height from AHN Surface (max value in meters)
NL_MIN_TREE_HEIGHT 5 Tree Height from AHN Surface (min value in meters)
NL_TRAFFIC_INFOMIL true InfoMil Ruleset
NL_TRAFFIC_INWEVA true INWEVA 24h Traffic Data
NL_TRAFFIC_NSL true NSL Monitoring
NL_TRAFFIC_NSL_CONVERSION 0.051 NSL Conversion from day to hour values (default 1.22 / 24)
OSM_BUILDINGS true Use OpenStreetMap for Buildings
OSM_LANDUSE true Use OpenStreetMap for Landuse
OSM_NEIGHBORHOODS true Use OpenStreetMap for Neighborhoods
OSM_ROADS true Use OpenStreetMap for Roads
OWNERSHIP true Ownership (cadastral data)
RISK_ASSESSMENT false Risk Assessment (detect e.g. dangerous objects like LPG stations)
SATELLITE_RESOLUTION HIGH Satellite background imagery resolution
TREES DEFAULT Tree options (DEFAULT, NONE or AI generated)
UNDERGROUND true Underground (soil type)
WATER true Water (rivers, canals, etc)
WORLD_WATER OSM Water (rivers, canals, etc)
ZONING false Zoningplan (limitations to buildings)
List of Geo Options
